Press the down arrow key and select Orientation to specify the orientation of the linear dimension.
You are prompted to Select option <Orthogonal>
Alternatively, input O at the prompt and press Enter to specify the dimension orientation as orthogonal.
Press the down arrow key and select Type to specify the type of linear dimension.
Press the down arrow key and select Direction to specify the direction of the dimension.
You are prompted to Select option <Left>
The option is only available for Combined Left, Combined Right, Baseline Left, and Baseline Right linear dimension types.
Press the down arrow key and select Position to specify the position of the linear dimension connection point.
Input A at the prompt and press Enter to position the linear dimension connection point after a specified snap point.
Alternatively, input B at the prompt and press Enter to position the linear dimension connection point before a specified snap point.
Alternatively, input P at the prompt and press Enter to position the linear dimension connection point at a specified snap point.
