DRAW
Introduction
General Functions
: Drawing Creation
Drawing Creation
You select the particular part of the 3D model and the direction and scale to use.
The 3D model can be viewed from any angle at any scale, including isometric views, with perspective if required. The appearance of the 3D graphics is controlled from representation rules that are pre-defined by the administrator allowing for different types of design items to have different line styles and colours applied to them. The required representation can be selected during view creation.
Various levels of wireline and hidden-line removal can be used. Sectional views can be generated by the creation of flat or stepped section planes, and there are no restrictions on the number of planes created or the selection of items that can be sectioned. The scale of the 3D graphics can be selected from a set of Metric, Architectural and Engineering values, with the option of an automatic scale selection to use the largest scale possible for the given design data and drawing sheet size.
