Software Customisation
PML 1 Expressions
Positions, Directions and Orientations in Expressions (AVEVA E3D™ only)
: Orientations
Orientations
The basic ways of defining an orientation are:
Orientation attribute plus optional WRT. For example:
ORI OF /BOX1 WRT /*
Cartesian orientation. For example:
dir IS dir AND dir IS dir
For example to set an orientation of an element to that of a section, rotated by 90 degrees use:
(E IS U WRT /SCTN1 AND N IS E WRT /SCTN1)
The AXES keyword, which will allow you to use P-points to specify orientations.
The syntax is:
>-- AXES --*--- PArrive ---|
|--- PLeave ----|
|--- PTail -----|
|--- HHead -----|
|--- HTail -----|
‘--- PPOINT n --+-- OF - <gid> ---->
An example is:
( AXES PLEAVE IS AXES PLEAVE OF PREV AND AXES P3 IS UP )
This will orient a branch component, such as a valve, so that it is aligned with the previous component and its P3 is up.
See also
Comparing Positions
