Software Customisation
PML 1 Expressions
Positions, Directions and Orientations in Expressions (AVEVA E3D™ only)
: Direction
Direction
The basic ways of defining a direction are:
Direction attribute plus optional WRT. For example,
HDIR OF /PIPE1 WRT /*
Cartesian direction. For example,
N 45 W
Cartesian direction WRT to an element.
All Cartesian directions are returned in the axis of the owner of the current element. For example:
(U WRT CE )
will return the Z axis of the current element relative to its owner.
Q ( Z WRT /SCTN )
will return the Z axis direction of /SCTN relative to the owner of the current element. For example, if the result is required in world coordinates the current element must be the World or a Site.
FROM pos2 TO pos2. For example
FROM N 50 WRT CE TO N 100
Keyword AXES followed by a p-point or pline.
The CLOSEST keyword, which will find the closest element in a particular direction. The syntax is:
>- CLOSEST type -+- WITH exp -.
‘------------+- DIRECTION dir -+- EXTENT val -.
‘--------------+--> cont
continued >-+- AFTER val -.
‘-------------+- FROM ? -.
In the above graph the keywords are:
EXTENT, which is how far to search in the direction specified, default 10M
AFTER, or the distance along vector after which to start search, default 0M
FROM, which specifies an alternative start point other than current element. This is of particular use for a branch where you might want to specify the HPOS or TPOS.
Examples are:
CLOSEST DIR E
CLOSEST BOX WITH ( PURP EQ ’FLOO’ ) DIR D WRT /* EXTENT 20M
CLOSEST VALVE DIR N 45 U FROM E100 N200 U300
CLOSEST BRAN HANG AFTER 2M
