Gives the position of the beginning of the leftmost occurrence of text2 in text1. If text2 does not occur in text1, 0 is returned.
ATANT returns the arc-tangent of number1/number2 with the appropriate sign. ATANT is useful where the second value is near or equal to zero.
ATANT (0.0,0.0) is undefined.
Give the largest display with of any string in array variable_name.
Return the length of text1.
Return the position of the beginning of the leftmost occurrence of text2 in text1. If text2 does not occur in text1, 0 is returned
Return the nearest integer to a real. NINT(N+0.5) is equal to N+1 if N is positive or equal to zero, to N if N is negative.
Scalar variable may not be indexed. For example, VTEXT (!var[1]) ) will return an error.
Array variable must have an index. For example, VTEXT ( !array ) ) will return an error.
