TRUE if id is invalid, else FALSE.
Matches string text2 to string text1. If they are the same then returns TRUE, else FALSE. text2 may contain wildcard characters.
Returns TRUE if value is unset, else FALSE. The value can be of any data type including ARRAYS. Normally it will be a attribute.
TRUE where DESC is an unset text attribute
FALSE where CRFA contains unset reference attributes
Scalar variables may not be indexed. For example, VTEXT(!var[1]) will return an error.
Array variables must have an index. For example, VTEXT (!array) will return an error.
