Software Customisation
Event Driven Graphics
Pick Data (edgPickData)
: Published Interface
Published Interface
The pick data object can be classed as being only a read-only objects, as setting the members within the object will have no effect on the operation of the event picking.
Method
The pick data object only has one method, this returns the pick data object as a picked position object.
Name
Result
Action
.positionData()
edgPositionData
Converts the pick data into a standard event position data object.
Members (General Picks)
The following are the definition of the members that are common to all the available picking types:
Name
Type
Action
.type
STRING
Basic type of pick on the graphics canvas, e.g. ELEMENT, PLINE, PPOINT, etc., etc.
.tubing
STRING
Tube type adjacent to the
.item
member, i.e. HEAD or LEAVE.
.item
DBREF
Database element picked.
.point
REAL
Ppoint or graphical aid number picked.
.pline
STRING
Structural pline picked.
.aidType
STRING
Basic graphical aid type picked, e.g. LINE, CYLINDER, etc.
.pickLine
POINT-VECTOR
Pick vector when picking an item, i.e. direction of view and the position of the direction on the viewing plane.
Members (Graphic Entity Picks)
The following are the definition of the members that are only populated by the graphical entity picks, these members define the basic graphical components of the item under the pick cursor:
Name
Type
Action
.vertexCount
REAL
Number of vertices, usually only 1, zero if a graphical edge or facet is picked.
.vertices
ARRAY
Position of vertex picked.
.lineCount
REAL
Number of edges/lines at the vertex point, 1 if only a graphical edge is picked, zero if a facet is picked.
.lines
ARRAY
Paired positions defining each edge/line.
.facetCount
REAL
Number of facets bounding the picked line or vertex, 1 if only a facet is picked.
.facets
ARRAY
Positions of each of the corners of the facets, four per facet.
