Software Customisation Reference Manual
Event Driven Graphics : Pick (edgPick) : Pick Filtering
[1] Pline, filter applied to display only plines of structural elements that conform to the defined rule.
[2] Ppoint, filter applied to display only ppoint of elements that conform to the defined rule.
[3] Element, filter applied to only allow elements that conform to the defined rule to be picked.
[4] Design Aid, filter applied to only allow design aids that conform to the defined rule to be picked.
[5] Tubing, filter applied to only allow implied tubing conforming to the defined rule to be picked.
[6] Graphical Entity, allow only the graphical entities defined in the member to be pick, these are, VERTEX, EDGE or FACET. If no entry is defined, then all graphical entities are pickable.
If this member is set to true this applies the standard filter to the pick when the pick becomes active. When false, the currently defined local rules within the .input member are used.
If you have defined some input rule, this member MUST BE set to false, otherwise the rules defined within the standard filtering utility will over-ride the settings when the pick becomes active.
