Picks types edgPickType defining the pick sequence.
Where pick packet definitions are supplied with arguments with a specific data type, then these values have to be supplied before the event packet is placed in the event system. However, where pick packets have an <any> argument type, the can be supplied as a pointer (expression) that evaluates into the correct data type when the action of the pick is evaluated.
Standard line object, contains the start point and end point. To extract the distance .length() is used on the element.
Standard arc object, centred on the root of the angle. To extract the angle .angle() is used on the element.
