Software Customisation
Event Driven Graphics
Event Control System (edgCntrl)
: View the Stack
View the Stack
There are two methods available to view the current state of the stack. These are only intended for use whilst developing AppWare and should only be used via the command line.
The outputs are directly written to the command request window, and look something like:
!!edgCntrl.viewStack()
Currently Active EDG Packet
Description
Key
Type
Priority
Initialisation
Action
Form
Remove
Input Data
Define a linear dimension
editDimension
measure
1
None
!!gphMeasure.setMeasure(!this.return[1])
GPHMEASURE
false
None
Pick Packet
Description
Standard Distance Measure
EDG Packet - Stack position [1]
Description
Key
Type
Priority
Initialisation
Action
Form
Remove
Input Data
Standard Navigate
stdNavigate
navi
10
None
!this.moveToDBRef()
None
false
None
Pick Packet
Description
Standard Element Pick
