Software Customisation
Event Driven Graphics
Components
: Main Components
Main Components
Main components are used to define and control the actual EDG system and should only be used in conjunction with the system.
The following table lists the main component names and gives a basic description of their function within the system:
Object
Description
edgCntrl
Controls and contains all currently active events that are registered in the system.
edgPacket
Defines a application/utility that requires graphical picks.
edgPickPacket
Defines the pick sequences and types of pick a packet requires.
edgPickType
Defines how a pick is to be interpreted.
edgPick
Defines the basic graphic pick, cursor style, filter, etc.
edgPosCntrl
Object for controlling all graphical position picks settings and active working planes/grids.
There are several other components that the system uses. However, these are to be classed as being private to the EDG system, therefore the AppWare developer should never access the directory.
