Software Customisation
Object Type Details
: VIEW Gadget: PLOT View
Members
Name
Type
Purpose
Background
REAL Get/Set
Get or set background Colour Number.
Background
STRING Set Only
Set background Colour Name.
Borders
BOOLEAN Get/Set
Get or set borders ON (TRUE) or OFF (FALSE).
Contents
REAL ARRAY[2] Get/Set
Get or set User Contents ID.
Defcall
STRING Get/Set
Get or set default interaction callback.
Height
REAL Get Only
Get view height.
Highlight
REAL Get/Set
Get or set highlight Colour Number.
Highlight
STRING Set Only
Set highlight Colour Name.
Prompt
GADGET Get/Set
Get or set User Prompt PARAGRAPH gadget.
Subtype
STRING Get Only
Get subtype of graphic view.
Width
REAL Get Only
Get view width.
Methods
Name
Result
Purpose
Add(STRING)
NO RESULT
Add plot file with name given by STRING. Replaces given plot file if any.
Background()
STRING
Returns the background colour as a name STRING.
Clear()
NO RESULT
Clear gadget contents
Highlight()
STRING
Returns the highlight colour as a name STRING.
Refresh()
NO RESULT
Refreshes the display of the gadget
SetSize(REAL width, REAL height)
NO RESULT
Set view size.
Command
The VIEW ... PLOT command puts you into View Setup mode. You remain in View Setup mode until you use the EXIT command.
(PLOT) --+- <vshap> -----------------------------------. |
+- ADD ā plot_filename -----------------------| |
+- CLear -------------------------------------| |
+- SETColour - <colno> -----------------------| |
+- SETHighlight - <colno> --------------------ā-
NL
+- <cursor> -----------------------------------------|
+- <border> -----------------------------------------|
+-- <pml> -------------------------------------------*
ā-- EXIT -->
Figure 2:8.
Syntax Graph -: Setting Up a PLOT VIEW Object
where:
<colno> is any valid AVEVA E3D⢠colour definition.
<cursor> is the syntax for selecting the cursor type, as in 2-19
<border> allows control of zooming and panning as in 2-20
