Software Customisation Reference Manual
Summary of Objects, Members and Methods : Object Type Details : TEXT Gadget
Sets the value of the field, checking for valid type and format. If validate is TRUE, the validation callback will be executed.
The IS word syntax allows for any user defined data type to be used, but this will only work satisfactorily if a suitable FORMAT object is supplied.
The maximum string length (SCROLL integer) is 256 characters, and the default if you do not specify a length is 132.
It is bad practice to place one gadget on top of another. This may lead to gadgets being obscured.
