Software Customisation
Object Type Details
: STATE
STATE
The STATE object provides an interface for interrogating and modifying the status of modify mode. It is only available to Design running in graphical mode.
Method
Result
Purpose
state ()
constructor
modifyMode ()
BOOLEAN
Returns TRUE if modify mode is on; else returns FALSE
modifyMode (BOOLEAN)
none
Sets modify mode on or off
enableModifyMode ()
BOOLEAN
Returns TRUE if modify mode is enabled, else returns FALSE
enableModifyMode (BOOLEAN)
BOOLEAN
If TRUE, then modify mode is enabled. If FALSE, modify mode is disabled unless it is already on, in which case this method has no effect.
The method returns TRUE if the action is successful, else returns FALSE.
.featureHighlight (BOOLEAN)
No Result
If TRUE, then features (ppoints, plines, vertices, etc) are temporarily highlighted in the 3d view as the cursor passes over them. Setting this to FALSE turns this feature off.
