Append an entry to the list, where Dtext is the text to display in the option list.
Append and entry to the list, where Dtext is the text to display in the option list, and Rtext is the replacement text for the new field. If Rtext isn’t specified, it will be set to Dtext by default.
Get the display text of the n'th field.
Select specified item in a selector. text must be ‘Rtext’ or ‘Dtext’. value is the field RTEXT or DTEXT to be selected.
Select multiple choice selector fields by value: text must be ‘Rtext’ or ‘Dtext’. The values array contains the RTEXT or DTEXT of the fields to be selected.
Get current selection: text must be ‘Rtext’ or ‘Dtext’. The value of Selection is the RTEXT or DTEXT of the selected field or fields.
Single choice. If DATABASE is not qualified, default is Members plus Owners. Auto update off.
