all at once, using the Results() methods;
a specified number of entries at a time, using the NextEntries()methods. Each entry will consist of one or more lines;
a specified number of lines at a time, using the NextLines()methods. This may cause a partial entry to be returned at the end, but the next call to nextLines will fetch the remainder of the entry.
Adds the column with the specified key to the report, with the passed column format. The argument heading is the column heading.
Used in conjunction with the '…MATCH' methods, defines whether matching is case sensitive.
Queries whether the MATCH STRING is case sensitive. Set using CaseMatch (BOOLEAN).
Evaluates the report using all entries of the table (there may be more than 1 line per entry. If column formats cause a wrap-around Rtext will be repeated). The return is TRUE if there are entries to evaluate, FALSE if there are no entries.
As above but only Dtext is evaluated.
Similar to Results() but only values matching the string are put into the two arrays.
Evaluates the report with the next n lines of the table, if column formats cause a wrap-around the Rtext will be repeated. The return is BOOLEAN to indicate if there are lines to evaluate.
