Software Customisation Reference Manual
Summary of Objects, Members and Methods : Object Type Details : POSTEVENTS Object
You may provide a PostEvents object, which should provide the methods described below.
The method !!postEvents.postMark will be called every time an undoable is created, after the undoable has been added to the undo stack.
Similarly, the method postUndo will be called after an UNDO has occurred, and so on. Each method will be passed a STRING object containing the name of the mark with which the mark, undo, or redo is associated.
Called after a clearMark has occurred
Called after a clearAll has occurred.
