If a paragraph is to contain text, then its shape will be specified in grid units. The height is the number of lines of text and the width is typically thought of as the number characters required. This may be less that the actual string length, because the grid width is the size of the font notional character width, which is typically smaller than the largest characters in the font. You may need to specify a few extra grid units to guarantee to fit variable strings.
If a pixmap is specified, the shape of the gadget must be defined and will be in pixels. Remember to define the pixmap using the paragraph's AddPixmap() method or its .Val member.
