Software Customisation
Object Type Details
: MDB Object
MDB Object
Member
Name
Type
Purpose
Name
STRING
Name of the MDB, up to 32 characters
Description
STRING
MDB description, up to 120 characters
Refno
STRING
String containing Database reference number
Methods
None of these methods modifies the original object.
Name
Result
Purpose
MDB(DBREF)
MDB
Returns an MDB object, given a DBREF.
MDB(STRING)
MDB
Returns an MDB object, given a name or reference number.
Current()
ARRAY OF DBS
Current databases as an array of DB objects
Deferred()
ARRAY OF DBS
Deferred databases as an array of DB objects
Mode()
ARRAY OF STRINGS
Returns ‘NR’ or ‘RW’ for each current DB of the MDB
You can use the constructors in the following ways:
!D = OBJECT MDB(!!CE)
!D = OBJECT MDB(!!CE Name
!D = !!CE.MDB()
!D = !!CE.Name.MDB()
In all cases,
!!CE
is assumed to be a DB database element and
!!CE.Name
is a STRING object containing the element’s name.
These methods should assist performance improvements to AppWare by making it easier to get from Database element to Object.
Command
!ARRAY= MDBS
$ Returns an array of MDB objects in the project
