Returns TRUE if where lies on the unbounded line.
Returns TRUE if where lies on the line, bounded indicates if the point is also checked to be on the bounded line segment.
Returns TRUE if where, when projected onto the line, lies within the bounded line.
Returns the intersection line of plane on the line definition.
Returns the intersection points of arc on the line definition.
Figure 2:2.
Returns a plane object, using the StartPosition and Direction of line object
Returns a POINTVECTOR object, using the StartPosition and Direction of line object
Returns a new line, maintaining the original StartPosition and direction, with an EndPosition to match length.
Returns a new line, maintaining the original EndPosition and direction, with a StartPosition to match length.
Returns a new line object with the same StartPosition and the same relative EndPosition (Length) of the original line, but the direction is from the start position to position.
Returns a new LINE, where the StartPosition has been extended in the opposite direction of line by distance.
Returns a new LINE, where the EndPosition has been extended in the direction of the line by distance.
Returns a LINE definition normalised onto plane. See picture.
Returns a parallel to the line definition of the line object, through position. All other members are copied. See picture.
Returns a parallel line to the LINE object, offset by offset from the original in the given direction. See picture.
Returns the overlapping line of two parallel lines. All positions are return projected onto the original object. See picture.
Returns the union of LINE and other. The two are parallel lines, all positions are return projected onto the original object. See picture.
