Software Customisation
Object Type Details
: DATETIME Object
DATETIME Object
Methods
Name
Result
Purpose
DateTime()
DATETIME
Create a DATETIME object with current date and time in it.
DATETIME(STRING)
DATETIME
Creates a local or a UTC date time e.g.: -
object DateTime('12:00 1 May 2018')
-Or append UTC for UTC suffix:
object DateTime('12:00 1 May 2018 UTC')
DATETIME(BOOLEAN)
DATETIME
Creates a local (FALSE) or UTC (TRUE) date time object using the date time when created.
DateTime(REAL year, REAL month, REAL date)
DATETIME
Create a DATETIME set to the given year, month, date. Time defaults to 00:00:00.
DATETIME(REAL, REAL, REAL, BOOLEAN)
DATETIME
As above but use the BOOLEAN argument to specify if the Date time object is Local (FALSE) or UTC (TRUE).
DateTime(REAL year, STRING month, REAL date)
DATETIME
Create a DATETIME set to the given year, month (using a STRING at least three characters long representing month e.g. 'Jan', 'March', 'DECEM') and date.
DATETIME(REAL, STRING, REAL, BOOLEAN)
DATETIME
DateTime(REAL year, REAL month, REAL date, REAL hour, REAL minute)
DATETIME
Create a DATETIME object set to given year, month, date, hour, minute. Seconds default to 0.
DATETIME(REAL, REAL, REAL, REAL, REAL, BOOLEAN)
DATETIME
DateTime(REAL year, STRING month, REAL date, REAL hour, REAL minute)
DATETIME
Create a DATETIME object set to given year, month (using a STRING at least three characters long representing month e.g. 'Jan', 'March', 'DECEM'), date, hour, minute. Seconds default to 0.
DATETIME(REAL, STRING, REAL, REAL, REAL, BOOLEAN)
DATETIME
DateTime(REAL year, REAL month, REAL date, REAL hour, REAL minute, REAL second)
DATETIME
Create a DATETIME object set to given year, month, date, hour, minute, second.
DATETIME(REAL, REAL, REAL, REAL, REAL, REAL, BOOLEAN)
DATETIME
DateTime(REAL year, STRING month, REAL date, REAL hour, REAL minute, REAL second)
DATETIME
Create a DATETIME object set to given year, month (using a string at least three characters long representing month e.g. 'Jan', 'March', 'DECEM'), date, hour, minute, second.
DATETIME(REAL, STRING, REAL, REAL, REAL, REAL, BOOLEAN)
DATETIME
Date()
REAL
Return day of month for this DATETIME object (1-31).
EQ(DATETIME)
BOOLEAN
Tests whether this DATETIME is the same as argument DATETIME. Local and UTC Dates times can be compared using the Current Time Zone.
GEQ(DATETIME)
BOOLEAN
Test whether this DATETIME is later than or the same as argument DATETIME. Local and UTC Dates times can be compared using the Current Time Zone.
GT(DATETIME)
BOOLEAN
Test whether this DATETIME is later than argument DATETIME. Local and UTC Dates times can be compared using the Current Time Zone.
HOUR()
REAL
Return hour as REAL for this DATETIME object (0-23).
LEQ(DATETIME)
BOOLEAN
Test whether this DATETIME is earlier or the same as argument DATETIME. Local and UTC Dates times can be compared using the Current Time Zone.
LT(DATETIME)
BOOLEAN
Test whether this DATETIME is earlier than argument DATETIME. Local and UTC Dates times can be compared using the Current Time Zone.
Minute()
REAL
Return minutes as REAL for this DATETIME object (0-59).
Month()
REAL
Return month as REAL for this DATETIME object (1-12).
MonthString()
STRING
Return month as STRING for this DATETIME object
(‘January’, ’February’, etc.)
Second()
REAL
Return number of seconds as REAL for this DATETIME object (0-59).
Year()
REAL
Return year as REAL
(e.g. 1998)
STRING()
STRING
Outputs the date time as a string including seconds.
ISUTC()
BOOLEAN
Outputs a boolean that determines if this PML date time is a UTC Date Time.
TOUTC()
DATETIME
Convert this (Local) Date Time to a UTC Date Time using the current time zone. Returns a new UTC date time object.
TOLOCAL()
DATETIME
Convert this (UTC) Date Time to a Local Date Time using the current time zone. Returns a new Local date time object.
SET()
BOOLEAN
Returns true if the year, month and date are all set.
