Software Customisation
Object Type Details
: CMSYS Object
CMSYS Object
Methods
Name
Result
Purpose
Command(STRING key)
PML Command
Returns PML command with given key
ExecuteCommand(STRING key)
NO RESULT
Executes command with given key
LoadResource(STRING path)
NO RESULT
Loads given resource file from %AVEVA_DESIGN_EXE% directory given file name (without file extension)
RefreshAll(STRING what, STRING how, STRING id)
NO RESULT
Refresh all commands sending given message
RemovePMLCommand(STRING key)
NO RESULT
Remove given PML command
SetApplicationContext(STRING context)
NO RESULT
Set application context to given string causing all command Refresh callbacks to be called
ShowCommand(STRING key)
NO RESULT
Make tool attached to given command visible
