Software Customisation
Object Type Details
: BAR Gadget
BAR Gadget
Methods
Name
Result
Purpose
Add(STRING dText, STRING enu)
NO RESULT
Appends a barmenu field, which can show the specified menu as a pulldown menu.
The name of the pulldown menu is given in
menu
; the DTEXT of the field is given by
dText
Clear()
NO RESULT
Removes all barmenu fields.
Using this method is deprecated
Clear(STRING dText)
NO RESULT
Removes all barmenu fields after and including the one
with DTEXT
dText
FieldProperty(STRING field, STRING property)
BOOLEAN
Get the value of the property named in
property
for the menu field named in
field
The allowed values for the property are ‘ACTIVE’ or ‘VISIBLE’.
FullName()
STRING
Get the full name of the gadget, e.g.'!!Form.bar'.
InsertAfter(STRING field, STRING dText, STRING menu)
NO RESULT
Inserts a new barmenu field immediately after the one identified by
field
The name of the menu is given in
menu
; the DTEXT of the new field is given by
dText
InsertBefore(STRING field, STRING dText, STRING menu)
NO RESULT
Inserts a new barmenu field immediately before the one identified by
field
menu
; the DTEXT of the menu is given by
dText
Name()
STRING
Get the gadget's name, i.e. 'bar'
Owner()
FORM
Get the owning form.
SetActive( STRING dText, BOOLEAN state)
NO RESULT
Deactivate/Activate the menu field whose DTEXT is
dText
SetFieldProperty(STRING menu, STRING property, BOOLEAN state)
NO RESULT
Set the value of the property named in
property
with the value of
state
, for the menu named in
menu
Shown()
BOOLEAN
Get shown status.
Type()
STRING
Get the GADGET type as a STRING.
Command
The BAR command creates a bar menu within a form definition.
The recommended way to create menu fields on the bar is to use the bar's
Add()
method.
bar
!this.bar.add ( 'Choose', 'Menu1')
!this.bar.add ( ' window', 'Window' )
!this.bar.add ( 'help', 'Help' )
The use of the two special menu names ’Help’, which adds a system help menu that calls the online help; and ‘Window’, which adds a system Window menu that lists all the displayed windows.
