Software Customisation
Gadget Syntax Graphs
: Setting Up Gadget Docking: <fgdock>
The DOCK attribute allows you to dock a gadget to the left, right, top, or bottom edge of its container, typically a form or a frame; or you can cause the gadget to dock to all edges, or to no edges.
>-- <fgdock> -----------+-- DOCK ----+-----Left ----.
+---- Right ‑--|
+---- Top -----|
+---- Bottom ‑-|
+---- None --‑-|
‘---- Fill --‑-’-->
The DOCK and ANCHOR attributes are mutually exclusive.
Setting the DOCK attribute resets the ANCHOR to the default; setting the ANCHOR attribute resets DOCK to none.
You can set these attributes only when you define the gadget: you cannot change it after the exit from form setup. Thus you are not allowed to the resize behaviour at run-time.
