Once the Write Data to File has been clicked three folders called
input,
output and logs are used to store the data.
The input folder contains the newly created CAESAR II Neutral file (*.cii) which can be input into CAESAR II.
The output folder contains an XML file which contains pipe stress data exported from AVEVA E3D™ in a predefined schema.
The logs folder contains a HTML reports viewable via a web browser: _log.html which contains information about the conversion from the *.xml file to the CAESAR II Neutral file.
