Pipe Stress Interface
Check Stress Group for Errors
: Node Errors
Node Errors
With the
Node Errors
tab highlighted, errors such as the component weight not being set are displayed.
These errors must be rectified before the pipe is sent to be stressed.
To see changes to the list of Data Consistency and Node Errors, refresh the Stress Group before selecting
Check Group
This will insure that all changes to the Stress Group are up to date.
Node Errors ‑ Weight
If the weight of a component such as an instrument is not set, then an error in the
Node Errors
tab is displayed:
Unable to Find Weight for INST /FE-117 (example)
INST =15392/5691 (example)
As there is no weight in the catalogue for this, it can be set locally in the design by use of a User-defined Attribute (UDA) called PSIWEIGHT. The PSIWEIGHT attribute value remains persistent once set and overrides the catalogue value.
