Pipe Stress Interface User Guide
CAESAR II to AVEVA E3D™ : Edit Return Nodes
To edit Return nodes, with the Export/Import tab highlighted, select Edit Return Nodes.
A Node Details window is displayed containing information on the returned nodes.
column is also set for active nodes. Any new nodes will be set to New. Deleted nodes will be set to Deleted and nodes which are unchanged are set to False.
