With the Export/Import tab highlighted, select
Convert Stress Data. If this is successful a new XML file (
StressGroupNameRet.XML) will be created and saved to the
Return folder which is located at the same place as the
input and
output folders.
A HTML log (*_RetLog.html) is created and stored in the logs folder every time
Convert Output is selected. The log gives more detail on what the conversion process has found and where, if any, problems have occurred. Any
Errors will be highlighted in Red,
Warnings in Blue and
Restraints in green.
