Accept Differences: A pair of linked elements having differences such as attribute values, sizes, connections or sequence, can be accepted as different.
Accept Missing Element: For unmatched elements, such as a drain connection, the corresponding elements can be accepted as missing. Integrator still matches the element if it is added subsequently to the 3D model.
Disable Matching: For elements that should not be matched, whether or not Integrator has currently matched them, matching can be disabled. For example: a tee for a trunnion,
