From a schematic element, when the Link option is selected, the Integrator searches for 3D elements that match according to the currently defined configuration rules. For example, for a schematic equipment, the Integrator looks for a corresponding 3D equipment element with a name or other attributes that complies with the rules. If a matching element that is not already linked is found, it is offered as the first in a list of candidates for linking, followed by unlinked non-matching elements.
        When the Unlink option is selected, a prompt may be displayed to select exactly which links are to be removed. For example, if schematic, design and engineering elements are all linked together, the schematic or just the design element can be selected, leaving the remaining link in place.
        Integrator maintains its links as separate CYMLNK elements against which it can hold important information. Each
CYMLNK object has attributes
deslnk referencing the 3D model element, and
schlnk referencing the schematic element. The
CYMLNK element also holds a
cmpstatus attribute to record its compare state. The 3D model and the schematic elements both have a
cmplnk attribute referencing the
CYMLNK object.
        To simplify navigation between corresponding schematic and 3D elements, Integrator provides the pseudo attributes schlnk and
deslnk directly between these two elements. The pseudo attribute
cmpsts returns the compare status description on the
CYMLNK object or on any linked schematic or design elements, or on its linked ancestor. It is included by default in the Integrator Main Table.
        Schematic elements have a Releaseto3dstatus attribute which should be set in the diagram authoring system. For example, AVEVA Diagrams provides a window to set this attribute. If the AVEVA Diagrams user then tries to modify a released object, they are prompted to confirm they do want to change it. If they do change it, the release status is unset P&ID Manager provides options to manage the release status of imported schematic data.
        The syntax for the Releaseto3dstatus attribute in the Main Table column setup is RESTAT. When set it has the value 1. It can be set from the command line with RESTAT 1.
        The Connection Details functionality is available for selection when a schematic equipment element is linked to a 3D equipment element or a E3D equipment element that is linked to a schematic equipment element.
        The Equipment Connections window is populated with the nozzles and electrical connections on the schematic equipment, and the 3D equipment. The Link columns are populated with which connections are linked between the schematic and 3D model. The window is also populated with the piping and HVAC nozzles and electrical connections. It also lists connections that are direct to the equipment elements using the ECRFA and ELCXRF reference array attributes.
        Use the Equipment Connections window, to change the specification reference of a nozzle, the
Pipework Nozzle Specification or the
HVAC Nozzle windows are displayed as appropriate. Or to create new nozzles or electrical connections and delete existing ones.
        The Pick Connection window is populated with the 3D branches that have unresolved connections. When a branch is selected in the Unresolved Branches list, the following actions are carried out by Integrator:
        The Connection columns are also populated with which branches are connected to which nozzles.
        Use the Pick Connection window to change the specification reference of a nozzle, select the nozzle in the
Connections list, then click
Modify Specification. The
HVAC Nozzle windows are displayed, as appropriate. Or create new nozzles and delete existing ones.
        To change which unresolved branch is connected to which nozzle, select the branch in the Unresolved Branches list, select the nozzle in the
Connections list, then select
Set Connection. The selected branch will be connected to the selected nozzle.
        Integrator can automatically link all matched elements from an Integrator Report, from the main menu bar, click
Edit > Link all matched elements.
        Individual links can be selected or skipped. Alternatively all matches can be linked, click Yes to All to automatically link all matches. On completion, the report indicates newly linked elements in cyan and any failed or skipped links in red.
        The Integrator Report window supports a drag and drop function from the
Diagram Viewer or
Design Explorer. The
Integrator Report window has a drop site for linking, at the base of the
Integrator Report window.
        An element can be dragged from the Diagram Viewer,
Design Explorer, or from the Integrator Report, and dropped in the drop site. If dragged from the Integrator Report, the action must start on either the schematic element cell or the 3D element cell to determine which element is to be dragged. A subsequent drop onto the drop site will either replace the element selected for linking, or offer to link to it, depending on the relative types.
        In the Main Table or
Diagram Viewer select the elements to link or unlink, then right click, from the displayed menu, select
Link or
Unlink.
        As previously stated, when Link is selected the Integrator searches for design or schematic elements that match according to the currently defined configuration rules and populates a window with the results. Thus enabling verification of consistency of 3D model against the schematic. Refer to
Schematic and 3D Links for further information.
        Which window is displayed is dependent upon where the elements is selected from, design elements are selected from the Diagram Viewer (Select Design Element to link to) and schematic elements are selected from the Schematic 3D Integrator Main Table (S
elect Schematic Element to link to). Refer to
Design Elements or
Schematic Elements for further information.
        Use the Select Design Element to link with XXXX window to select an element to link to.
        Use the Select Schematic Element to link with XXXX window to select a schematic element to link to.
