Integrator can build in the current SITE and ZONE if there is no rule to define the SITE or ZONE. In order to get Integrator to build in the current ZONE, use the Main Table > Build. Click in the Diagram Viewer to use its right click menu, the current element will be changed to the schematic object, and Integrator will no longer be able to build in the intended ZONE.
The Build functionality is only available when the element is not linked or matched.
If a specification reference has not been set on the schematic component, Integrator tries to choose the 3D component from a pipe specification using available data. Integrator determines the appropriate specification, generic type and bore(s). Other selectors such as STYPE can be set by the rules. If Integrator has insufficient data to make a single choice, a warning is displayed in the Integrator Comments window, along with a drop down menu populated with specifications available for selection.
