Select Main Table Menu > Main Object Type to select a new main object type from the submenu. The full list of available main object types are:
To select whether the table will include all instances of the Main Object Type from the current
MDB, or only those instances from all pages of the
Diagram for the currently displayed
Page (default), or only those instances on the currently displayed
Page. Select
Main Table Menu > Scope for Schematic Types.
Use the Column Setup window to view the columns already defined for the table, add or delete columns and add standard attributes. Select
Main Table Menu > Column Setup to display the table column setup window.
The functionality available from the Column Setup window is common throughout AVEVA E3D™, refer to
Set Columns in the Search Results for further information.
The release to 3D status for a schematic object can be displayed in the main table using the attribute RESTAT. The compare status can be displayed using the attribute
CMPSTS. To filter the main table on schematic elements that have been released but have not been linked, filter on
RESTAT equal to 1 and
CMPSTS equal to 'Not linked'. For more details of schematic to 3D links refer to
Schematic to 3D Links.
Use the functionality available from the Settings menu, is common throughout AVEVA E3D™, refer to
Search Results Settings for further information. Select
Main Table Menu > Settings to display the menu.
To edit attribute data in the main table, select Main Table Menu > Settings > Interactive Mode to display the menu, select an appropriate Interaction Mode:
The current table layout and content can be saved to an Excel file. Select Main Table Menu > Export To Excel and enter a filename in the file browser.
Select Main Table Menu > Save Layout to save the current main table layout. If the current layout has not yet been saved as a named layout, a prompt to enter a name in the
Save Layout As window is displayed.
Select Main Table Menu > Save Layout As to save the current main table layout as a named layout for the current main type. Multiple named layouts for each main object type can be saved. For example, you may choose to display different attribute and column filters for pumps and vessels, and save them accordingly.
The Subtype Table Menu main right click menu are accessed by clicking the right mouse button in the Subtype Table column title bar, either with no rows selected, or by clicking in the column title area if one or more rows are selected.
The functionality available from the Subtype menu window is common throughout AVEVA E3D™, refer to
Main Table Menu for further information.
