Before modelling a pipe, the correct database elements should already be present in the Model Explorer, for example, a World, Site and Zone should exist. If this is not the case, refer to
Database Hierarchy for more information.
Below the zone level in the PIPING discipline, the specific elements are:
By default the Primary System is No System, to change the type of primary system select a system from the
Primary System drop-down list.
The Bore specifies the nominal bore and does not affect the pipe route (the default is unset).
Select an Insulation specification, if no insulation is required (the default is None), select
None.
Select a Tracing specification, if no tracing is required (the default is None), select
None.
In Temperature, enter the temperature to which the pipe can reach (the default is ‑10000degC, this means that the temperature is ignored).
In Pressure, enter the pressure to which the pipe must withstand (the default is 0pascal).
The Slope Ref specifies the slope reference attribute, which is governed by the catalogue (the default is none). To change the slope reference attribute, select a slope reference from the
Slope Ref: drop-down list.
Click Apply, to create a new pipe and branch element in the Design database and display the
Pipe Editor: Modify Pipe window, to define the branch, refer to
Branch Element for further information.
The Pipe Editor: Modify Pipe window displays by default when a new pipe element is created. It is a dual purpose window which allows the definition of branch attributes and/or connect the branch head and branch tail or modify an existing branch.
By default, the Pipe Editor: Modify Pipe window is populated with the attributes of the CE, if required, select another pipe as the CE.
Use the Pipe Editor: Pipe window to select an alternative
Pipe Specification by clicking
Modify Pipe Attributes to display the
Pipe Editor: Modify Pipe specification window.
The Pipe Editor: Modify Pipe specification window has the same functionality as the
Pipe Editor: Create Pipe window, refer to
New Pipe Element for further information.
The Connectivity part of the
Pipe Editor: Modify Pipe window displays the connectivity status of each branch within the pipe assembly.
If required, select an alternative Branch Specification by clicking
Modify Branch Attributes to display the
Pipe Editor: Modify Pipe branch specification window.
The Pipe Editor: Modify Pipe branch specification window has the same functionality as the
The Branch Head and
Branch Tail tabs on the
Pipe Editor: Modify Pipe window, are used to define the connection and position of the branch head or branch tail. As the functionality for the definition of the branch head or branch tail is identical, for the purposes of this user guide, only the branch head definition is described. By default the branch head tab is selected when the
Pipe Editor: Modify Pipe window displays.
The Branch head tab of the
Pipe Editor: Modify Pipe window is used to connect the branch head and define basic branch head details, the connection status of the selected branch displays by default:
The Bore,
Connection and
Direction fields are automatically populated.
In the Bore drop-down list, select the nominal bore of the pipe from the list of available sizes in the catalogue.
In the Connection drop-down list, select the type of head connection from the list of available connections in the catalogue.
The Direction specifies which direction the flow takes from the Branch Head. (The head direction is the direction of flow and the tail direction is the opposite direction of the flow).
Use the Position wrt World: part of the
Pipe Editor: Modify Pipe window to position the branch head explicitly.
If required use the positioning aids available for selection from the Positioning Control window, to select the head position on the. 3D graphical view.
Once selected the Position wrt World: part of the
Pipe Editor: Modify Pipe window is populated.
If required, nudge the head direction, from the Position along centre part of the
Pipe Editor: Modify Pipe window. The nudge distance is controlled by the nudge increment which is set to 100mm by default.
Pick the head position along a selected centre line, from the Position along centre part of the
Pipe Editor: Modify Pipe window, click
Select the Create Head Components checkbox to create gasket/flanges at the head.
Click Apply to create the head/tail.
Click Set working pipe, to identify the element as the CE, the attributes of the element are automatically populated in the
The Branch Head tab of
Pipe Editor: Modify Pipe window indicates that the selected branch head is connected.
From the Branch Head tab of the
Disconnect head to disconnect the branch head from the element it is connected to.
Click Set working pipe, to identify the element as the CE. The attributes of the element are automatically populated in the
Pipe Editor: Modify Pipe window indicates that the selected branch head is connected but requires reconnection.
Click Reconnect to reconnect the branch head to the equipment element.
Pipe Editor: Modify Pipe window indicates that the selected branch head is undefined.
Pick item to connect head to, then
Identify element to connect to:, select the element to connect to in the 3D graphical view.
The Connect to: field on the
Branch Head tab is populated with the element name.
The List of connections: is populated and displays the connection status of each connection component.
Connect the branch to the selected element in the List of Connections. Alternatively a connected branch can be disconnected from an element.
Click Yes to disconnect the selected connection.
Click No to discard any inputs and close the Confirm window.
From the quick pipe routing right click menu, select Component Choice > Set Default Bend Radius, the
Bend Radius Choice window is displayed. The
Current Branch is displayed and
Bending Machine is selected as default.
The Bending Machine part of the
Bend Radius Choice window indicates that the bending machine must be selected.
Bend Radius Factor - Use the bend radius factor to specify a factor which takes the current tube outside diameter and multiplies it by the factor available for selection from the
Bend Radius Factor drop-down list. The bend radius factor is l then be used on all subsequent bends giving the appropriate radius according to their outside diameter.
Bend Radius - Explicitly enter a radius in the
Bend Radius field, the bend radius is then be used on all subsequent bends giving the appropriate radius according to their outside diameter.
By default, No Slope is selected (no slope will be applied to the pipe leg). To set the sloping angle, select
Slope Angle, the
Set Slope Angle window is displayed.
Enter the sloping angle, click OK to apply the sloping angle, quick pipe router will route the pipe with the sloping angle or click
Cancel to discard any inputs and close the window.
Click Connect head to first branch member to connect the branch head to the first member of the branch.
A new branch is created in the Model Explorer and in the Connectivity part of the
Pipe Editor: Modify Pipe window. Populate the
Pipe Editor: Modify Pipe window with details and connections as required. Refer to
Define Branch Head and Branch Tail for further information.
Use the Pipe Sketching functionality to access design aids and tools to create a branch, insert components, copy and mirror piping components.
Select an aid point from the Points drop down list, to view the frame, offset and world position of an aid point.
Use the Orthogonal functionality to view the line between the aid points in the 3D graphical view as orthogonal.
Use the Offset functionality to offset an aid point in the 3D graphical view.
Use the Mirror Component Selection functionality to mirror an existing branch element.
Referring to the Database Hierarchy, a pipework component must reside below an existing pipe branch element. Refer to
Branch Element for a more detailed explanation of creating a pipework branch.
The Spec:,
Bore: and
Branch Slope: of the currently selected pipe displays at the top of the window.
Select a specification from the Select From Spec drop-down list. If a specification is selected that does not match the pipe specification,
the Piping Component Editor window displays a
Select Out of Spec message.
Click Spec: to return the
Select From Spec drop-down list to the current branch specification.
Select an insulation specification from the Insulation drop-down list. If no insulation is required, select
None. (If a new specification is required, refer to the system administrator).
Select a tracing from the Tracing drop-down list. If no tracing is required, select
The Standard Components tab (displayed as default) provides quick access to the more commonly used components.
The Select tab displays all of the components available for selection from the catalogue under the currently selected component and piping specification.
The Additional Components tab provides quick access to further components
The Select tab displays all of the additional components available for selection from the catalogue under the currently selected piping specification.
Click OK to select another component.
The component information part of the Piping Component Editor window displays information specific (if relevant) to the selected standard or additional component.
Click Flange from the
Standard Components tab to display the
Reducing Flange Information in the
Piping Component Editor window.
The Leave Bore drop-down list is not used for a flange.
Click Elbow from the
Elbow Information in the
Click Tee from the
Connection Information in the
Select a value from the Conn Bore drop-down list.
Click Reducer from the
Reducer Information in the
Select a value from the Leave Bore drop-down list.
Click Bend from the
Bend Information in the
Select a value from the Radius drop-down list.
Select Define from the
Radius drop-down list to input a bend dimension.
Click Olet from the
Click Coupling from the
Reducing Coupling Information in the
Click Assembly from the
Additional Components tab to display the
Assemblies part of the
Choose from a list of available assemblies in the Available sub-types for component drop-down list. The assemblies available for selection are those already created in the catalogue, if the required assembly is not included, refer to the system administrator.
Use the Create Mode part of the
Piping Component Editor window to set the direction of flow, the software creates the component in the Head to Tail direction by default.
If the Auto. Create check box is selected, the software automatically determines if there is a requirement for an associated component (on a valve, the associated component would be a flange and gasket) and if so, what is the appropriate.
If the Out of Spec check box is selected, an alternative specification component can be used.
If the Skip Connected Comps check box is selected, the pipework application automatically determines which components are connected, then positions the creation point approximately.
Use the Create Components part of the
Piping Component Editor window to connect or place the component.
Use the Create Assemblies part of the
Piping Component Editor window to connect or place the assembly.
Use the Component Sequence List part of the
Piping component Editor, to scroll through and select individual components within the currently selected branch.
The CE is highlighted in the centre of the Component Sequence List, if required select another component in the sequence list.
Use the Position Through part of the
Piping Component Editor window to adjust the position of a component.
The 3D Compass part of the
Piping Component Editor window can be used in two ways depending upon the type of component selected. By default, the
Direction Tool is displayed as default.
Direction Tool: the direction of elbows and bends can be changed.
Rotation Tool: tees and other non-symmetrical components such as valves or reducers can be rotated.
Use the Direct Component view displays a compass which to set the orthogonal direction of a component using the direction arrows and the direction plane selector of the compass.
To direct the component using a direction plane, click the Direction Plane Selector of the direction tool to set the direction plane. For example, click the top right section of the
Direction Plane Selector to change the direction plane. The direction plane displayed depends upon the original orientation of the component.
Use the Rotation Tool to change the rotation orientation of a component using the rotation dial. Click Rotate Component to display the
Rotation Tool. Dependent upon the currently selected component determines how the rotation tool is displayed.
Use the Bolt Hole Alignment window to rotate a flanged component so that it aligns with the bolt hole spacing by default, which means using the number of bolt holes in the component to determine the default angle increments of rotation.
Click Rotate By Bolt Hole Angle Increments Only, then select the rotation angle which is no longer constrained by bolt hole alignment. A
Question window is displayed:
Click Yes to rotate the connected flanged components to the angle.
Click No to close the
Question window.
Click Cancel to discard any inputs and close the
Question window.
To return to 3D compass view of the Piping Component Editor window, click
Direct Component.
Use the Orientation part of the
Piping Component Editor window to adjust the orientation of a component.
Use the Other part of the
Piping component Editor, to manipulate components and pipework.
Displays the Drag Move window when a component is selected in the Model Explorer. Refer to Advanced Move for further information
Displays the Drag Move Branch window when a branch is selected in the Model Explorer. Refer to Advanced Move for further information.
Displays the Move window when a component is selected in the Model Explorer. Refer to Advanced Move for further information.
Displays the Move Branch window when a branch is selected in the Model Explorer. Refer to Advanced Move for further information.
Use the Reselect tab to replace a piping component from a list of available components, select the
Reselect tab to display the CE’s attributes and properties. The
Reselect tab of the
Piping Component Editor window displays all the components available from the catalogue under the current piping specification.
Select a component from the Type drop-down list to filter the component type to modify.
Select a component specification from the Sub-Types drop-down list to filter the component by sub-type.
Select Reconnection to re-establish adjacent connections. If an error occurs when the components is replace, the error tab displays, populated with the error.
With the Errors tab selected, the
Piping Component Editor window lists the components selected fro modification which produce an error in the selection process. An error is indicated with a description in the error list.
Use the Non-standard Branch Connections window to connect existing branches.
From the Main Branch pane, click
Select, the prompt
Identify Main Branch is displayed.
Once the selection has been made, the selected branch name, bore and wall thickness are displayed in the
Non-standard Branch Connections window and the
Connect Existing Branch check box is automatically selected.
From the Select Branch pane, click
Select, the prompt
Identify Stub in Branch is displayed. Once the selection has been made, the branch connects to a cartesian point (PIPCA) owned by the component. The selected branch name and bore are displayed in the
Non-standard Branch Connections window. As the branch is not yet connected the
Current connection details part of the
Non-standard Branch Connections window head and tail are not connected.
Use the Connection Details part of the
Non-standard Connections window, to set the connection and tapping type, bore size and insert depth.
The Branch Type can be selected from the drop-down list:
In the Note field, add a fabrication note which will appear on the piping isometrics
The Insert Depth value varies according to the
Branch Type selected and is calculated using a set of standard calculations for branches on centreline. In some cases the calculation may need to be adjusted by eye to provide a more accurate material length. To do this enter a value into the
Insert Depth field. The value shown in this field can be one of three types:
Click Apply to create the connection or click
Dismiss to discard any inputs and close the
Non-standard Connections window.
Use then Non-standard Branch Connections window to connect a new branch, click
Select, the prompt
Identify Main Branch is displayed. Once the selection has been made, the selected branch name, bore and wall thickness are displayed in the
Non-standard Branch Connections window. Select the
Connect New Branch check box.
The Create New Branch pane is automatically displayed with a name for the new branch. Click
Pick connection Point, the prompt
Pick a surface Position to locate initial branch position: is displayed.
The Locate Branch window is populated with the direction of the plane and branch also with the angle at which the new connection point is initially positioned.
If required, position the new connection, use the Nudge and
Rotation parts of the
Locate Branch window.
Click OK to position the connection at the new location or click
From the Connection Details pane, set the connection and tapping type, bore size and insert depth.
