Piping
Piping Defaults : Piping Settings
The Component part of the Piping Application Defaults window sets the default settings on the Piping Component Editor window.
The Data Consistency window must be used to set up the minimum tube lengths for different bore sizes.
If the Snap Distance and Min Tube check boxes are selected, the tube tolerance check options (Datacon) are used.
Displays the point direction option on the Piping Component Editor window.
The Pipe/Branch part of the Piping Application Defaults window sets the default pipe editor settings on the Piping Component Editor window.
The Reselection part of the Piping Application Defaults window sets the default component selection settings on the Piping Component Editor window.
Reconnects components that are modified using the Reselect tab. Reconnection errors display in the Errors tab.
The Laser Data part of the Piping Application Defaults window sets the default settings for laser settings on the Piping Component Editor window.
The Direction Display part of the Piping Application Defaults window sets the default display settings on the Piping Component Editor window.
