Select Spec to create a weld from the current pipe spec. The weld thickness is pre-defined by the spec.
By default the Include Spool Limits check box is selected, allowing you to Include Spool Limits within the deletion.
Click to display the Component Attributes window. Refer to Modify Component Attributes for further information.
The check box becomes active when the user selects the Loose Component check box, the Offline Component check box must be left unchecked and the component must be positioned at the end of a spool.
Pick first component or <ESC> to finish : on the 3D graphical view
If the Add/Remove Spool Limits - No Welds is selected the weld is not displayed on the 3D graphical view.
Pick a second component, a Confirm window is displayed asking OK to remove, click Yes to remove the spool limit.
If the spool limit location on the currently selected pipe already has a spool limit created without a field WELD component and Add/Remove Spool Limit - Welds is selected, the following Confirm window is displayed:
Click Yes to replace the spool limit - without a weld component with a weld.
Select the radio button and specify the Arrive to define the spool arrive end as the machine insertion direction.
Select the radio button and specify the Leave to define the spool leave end as the machine insertion direction.
Select from the drop-down list to create a Department element. Enter a Department Name in the field to the right of the drop-down list, the element displays in the Fabrication Explorer.
Select from the drop-down list to create a Registry element. Enter a Registry Name in the field to the right of the drop-down list, the element displays in the Fabrication Explorer.
Select from the drop-down list to create a Spool Drawing element. Enter a Spool Drawing Name in the field to the right of the drop-down list, the element displays in the Fabrication Explorer.
Click to display the Default Fabrication Machines part Fabrication Check window. Refer to Default Fabrication Machines for further information.
Use the Select Fabrication Machines window to view the default bending machines available for selection.
Selects the default fabrication machines to be used instead of the fabrication machines specified by BendMacReference in fabrication checks. Refer to Default Fabrication Machines for further information.
Generates spool and piece elements for the currently selected pipes, the status is set to Ready for fabrication regardless of outstanding warnings.
Displays the Optimization Priorities window, use it to order the optimisation priorities for the fabrication check. The modified priorities are temporary and is invalid after closing the Fabrication Check window. The functionality of the Optimization Priorities window is explained as part of the process for defining Optimisation Criteria for Bending and Welding. Refer to Optimization Criteria for Bending and Welding for further information.
Use the Select Fabrication Machines window to view the default fabrication machines available for selection.
Generates spool and piece elements for the currently selected spools, sets the status to Ready for fabrication regardless of outstanding warnings.
Use the Select Fabrication Machines window to view a list of available fabrication machines for selection.
