Select an FMWLD, FMGRP or FMBEND from the drop-down list to assign a BendMacReference attribute value to the selected element.
Select the check box to tidy the BendMacReference attribute value of the selected element by default. Refer to Tidy BendMacReference Element for further information.
BendMacReference is not defined.
If required, enter a statement in the Drawing Note field, the default is Plain End, the note is displayed on the drawing.
Click Create Sniped Ends, select a pipe end in the 3D graphical view.
The prompt ‘Pick pipe end:’ is displayed.
Specify the angle for the Sniped End and display a Drawing Note.
Enter a value (greater than 0) in the Slanted Angle field to define the angle of the Slanted End in degrees.
If required, enter a statement in the Drawing Note field, the default is Trim pipe end to {deg}, the note is displayed on the drawing.
Click Create Sniped Ends. The user must select a pipe end in the 3D graphical view.
Enter a value (greater than 0) in the Sniped Angle field to define the angle of the Sniped End in degrees.
Enter a dimensional value in the Clearance field to define the reference plane clearance.
Click Create Sniped Ends with Reference Plane.
Click Create Threaded End. The user must select a pipe end in the 3D graphical view.
Select a Threaded Type from the Thread Type drop-down list.
The user can configure the Thread Type, refer to Threaded Ends for further information.
