AVEVA Global User Guide
Monitoring Command Progress
Success and Failures from Scheduled Updates
: Scheduled Update ‑ Failures
Generally a scheduled update will always succeed with a number of database failures
Failure messages will contain detailed reasons:
In this case, the databases could not be propagated, since the secondary database had a higher compaction number than the primary database. This may happen when a remote merge is executed without stopping scheduled updates. Normally it will be necessary to recover the database to resolve this error.
Prevention of Reverse propagation may also be reported in the following situation ‑ a satellite has executed a direct update (UPDATE DIRECT from the command-line) with a non-neighbour satellite. The next scheduled update with the intermediate location will report ‘Prevented reverse propagation’. In this case, scheduled updates will eventually resolve the situation.
The following table summarises Failure messages that can be generated for Scheduled updates. This does not include all possible failures that may be generated from failed file copies.
Error No
Symptom
Reason
Scheduled update was suppressed
Attribute LNOUPD set TRUE on LCOMD to disable scheduled update
Remote location CAM is unavailable
Daemon for CAM is not available;
Update will not report results to CAM
this failure cannot be reported at CAM ‑ usually due to location unavailable
612
Prevented reverse copying
Secondary location has a higher compaction number than the primary location. Database may need recovering
611
Prevented reverse update
Secondary location has a higher session number than the primary location. Database may need recovering
613
Unable to check update direction ‑ update skipped
The Global database is in use. This is normally temporary, due to another command.
610
Update skipped ‑ cannot get local details for <database>
The specified database is in use at the current location. This is normally temporary, due to another command using the database.
610
Update skipped ‑ cannot get remote details for <database>
The specified database is in use at the remote location. This is normally temporary.
610
Update skipped ‑ cannot get local/remote details for CAM system DB
In the case of system databases, if one system db is in use, then the update will fail for any system db (they all have the same DB number)
Failed database copy ‑ file may be in use at HUB
Unspecified COPY failure ‑ compaction numbers are still out of step. If the copy destination was the update location, then additional failures will give further detail.
619
Cannot verify success - may be failed COPY
Unspecified COPY failure ‑ compaction numbers are still out of step. No further detail is available.
Missing remote/local file. Prevented reverse propagation.
System databases only. A system database file is missing at the specified location. This may need to be recovered.
615
Update failure ‑ possibly database error
A database error was encountered during the update. Full detail will be in the daemon log
614
Update failure ‑ database pages are not contiguous
The database file is corrupt at the destination. This database must be recovered from its primary location.
628
Failed database copy. File in use. Cannot remove
Database file is locked and overwriting is disabled. File copy has failed to commit the .admnew file. The .admnew file will be retained for later use.
630
Failed database copy - update for previous extract failed
Prevention of an inconsistent extract hierarchy. A file copy for an extract db has not been attempted because of an update failure on another extract of the same database. (
Not fully working at Global 2.4
