AVEVA Global User Guide
Hub Administration
: Administering System Databases
A System Administrator at any location can administer the System database for a Satellite location, provided that the Satellite’s System database is primary at the administering location. The administering location can be the Hub or a Satellite location. If necessary, change the location of a System database to make it primary at the administering location: refer to
Changing the Primary Location
From the ADMIN menu bar, set the
Administering
option gadget to the location where you want to administer the System database.
For information about the commands that are available when you administer the System database for a Satellite, refer to
Local Administration
