Location groups consist of several locations which all have direct communication links with each other. This means that there will be communication links within a group which do not correspond with parent-child relationships. In the following diagram, the dotted lines show these links.
There is one location in the group which is the Root: this is the first location on the route from the Hub to the group.
A group is set up by creating it using the Admin Elements window, and then adding the locations which will become its members using the
Group Membership window, which is displayed when the user clicks the button at the right of the
Group text box on the
Create/Modify Location window.
