AVEVA Global User Guide
Hub Administration : Using Different Database Areas in Global Projects
The user can use different areas for databases in Global projects in that same way as standard projects. Make sure that the environment variable for a database’s area must be set at all the locations to which it is allocated, otherwise the database cannot be propagated correctly.
