The Global daemon is dependant on a valid AVEVA License. For more information relating to licensing refer to the AVEVA Licensing System (ALS) guide.
If transfer of other data files is required (refer to Transfer of Other Data), then import (IMPORT) and export variables (EXP_XYZ for export to location XYZ) must also be set up.
