the hostname, which is found by typing hostname in a command window.
the IP address:
the fully-qualified domain name e.g. hub.domain.com.
Working Extracts, Location HUB
Working Extracts, Location TWO
Working Extracts, Location THR
This is an example extract number range for illustration purposes. For a more detailed explanation of extract numbers refer to section Extracts of the Running Global Projects.
Click Yes, the Hub will be initialised with the current settings on the window. These settings can be changed later, if necessary. Make sure that the Hub has a transaction database before its initialised.
Click No, the values entered on the window is stored, and are still editable to change them.
Click Dismiss, the window is closed and any changes lost, as normal.
