AVEVA Global User Guide
Authenticating Global with your AVEVA Connect Account
: Running the Global Daemon with LaaS
To run the Global daemon with LaaS, the environment variable AVEVA_LICENSE_SERVER_LIST will use a URL instead of port@hostname. For example:
AVEVA_LICENSE_SERVER_LIST=https://some-license-address.com
Make sure the associated Global Licenses (GLOBAL/ GLOBALSAT) are present in the associated AVEVA Connect account.
Run the daemon. If authorisation is unsuccessful, the daemon will terminate with an appropriate error.
