AVEVA Global WCF Configuration Guide
Start a Global Project
Start a Global Project section summarises in brief how to start an instance of Global on a machine. Throughout the section reference is made to the Global User Guide which describes then standard process of starting a daemon. Any differences in WCF configuration are clearly highlighted in this section.
In brief the administrator must load the Admin module within the base product and issue the following commands at the command line to convert the project for Global use:
The user must continue to refer to the AVEVA Global User Guide to Initialise the hub location, refer to Single Project Service for further information.
