AVEVA Global WCF Configuration Guide
Firewall Configuration
: Open Ports in Windows Firewall
The choice of firewall technology implemented in an organisation will vary, but to illustrate a configuration the following section shows how the administrator can configure the built in firewall supplied.
Although simplified, the principles demonstrated in this section apply to all firewall vendors.
Type
Firewall
in the search field on the PC and select
Windows Defender Firewall
from the returned results.
In some cases the Firewall configuration can be can be controlled by a Group Policy on the network Domain Controller. In this case the administrator can configure the firewall settings centrally on the domain controller.
Click the
Advanced settings
link.
Click
Inbound Rules
or
Outbound rules
to create or modify a rule.
Important:
The administrator must repeat the process to add an open port to any satellite daemons on other machines in the network to establish a clear two way communication without being blocked by the firewall.
