AVEVA Global WCF Configuration Guide
Trust Boundaries
In this environment no security is required so the administrator can set the Binding to unsecured method of communication such as basicHTTP or TCP. This will also allow for faster data transfer within this type of network.
Encryption can be set to none.
The administrator could consider using Encoding. Binary through TCP would provide the fastest solution.
Authentication None required.
The administrator must use Transport Level Security where connections are already protected through a VPN (Virtual Private Network) and Message Level Security where there is no VPN.
For Authentication use Windows Authentication if on the same domain and Certification if not.
