AVEVA Global WCF Configuration Guide
Security Features
: Authentication
Authentication
Authentication will make sure that communication is valid by checking that the sender and recipient are valid.
Messages are sent to a known recipient.
Messages are received from a known sender.
Authentication can be applied to the connection or to each individual message.
through
Windows Login Accounts
Can be used when communications are within the same domain/organisations. If communication is between different domains/organisations then use Certification.
Certification
Use a certificate at both ends of communication to check authenticity.
The user must purchase a valid certificate from a provider; refer to
Certificate Based Authentication
for further information.
