AVEVA Global WCF Configuration Guide
Software Checklist
Software Checklist
The user must check that the following items have been installed.
A valid license file
Microsoft .NET Framework 4 (refer to
Microsoft .NET Framework v4
The latest version of the base product with WCF enabled
The latest version of Global Server with WCF enabled.
The user can optionally configure the Global WCF to use a Secure Socket Layer (SSL) certificate. If this is the case then the following pre-requisites apply:
A pre-purchased SSL Certificate (described in detail in section
Certificate Based Authentication
Windows Server 2003 Service Pack 1 Support Tools (If the Operating System being used is Windows Server 2003). This is required if the steps described in section
Bind Certificate With Windows Server 2003
are to be followed.
