The Customize Explorer is populated with a representation of the active customization. It shows CommandBars and their contents, Menubars and their entries, Context Menus and their entries and Ribbons and their contents defined in all of the configuration files above and including the currently selected file. It also contains a list of the currently loaded resource files.
If the selected node represents a resource file, the Resource Editor will be displayed instead of the property grid.
Use the right-click menu available from the List of Command Tools pane of the
Customize window to delete, create a tool or get an image from the clipboard.
Delete - Deletes the currently selected tool, if the selected tool is not editable then the delete operation is disabled. If the tool has been used then a warning message is displayed to confirm that the delete should be carried out.
New - use the displayed menu to create a new menu tool, create a new tool of the required type with a unique default name (Tool<N>) and add it to the list. New tools can also be created using the icons on the left side of the command tool pane.
If required, the command property can be modified, click . . . in the
Command field to display the
Command window. By default the command type is set to
Command, other command types available for selection are
Macro and
Command Class, refer to
Macro and
Command Class for further information.
Use the functionality available from the Command window, to select a command class from populated list:
Use the Edit Formatted Text window to edit existing resource(s), right click the required string resource in the property grid, from the displayed menu select
Formatted Text Editor.
Use the standard functionality available for selection from the View Style menu to change how information is displayed in the
resource file editor.
