.NET Customisation
.NET Customisation
How to Write a CAF Addin
: Exception Handling in a CAF Addin
The code of all components of a CAF Addin is executed within the event loop of the host AVEVA program. Any exception raised within the Addin code, or any code called by it, that is not caught by the addin code itself will have to be handled in the event loop. The AVEVA host has effective ways to handle some classes of exceptions - namely PdmsExceptions and PMLNetExceptions. In the situation where the host program is in the process of executing PML, then the PML first has an opportunity to handle the exception itself. If the PML does not handle the exception, or if no PML is currently being executed, the host program handles these exceptions by notifying the user of the exception text and number interactively via the Status Bar, MessageBoxes or the CommandLine display as appropriate. Event loop processing then continues normally.
For all other classes of exception the host event loop has no standard procedure and the outcome is that the host program terminates untidily. It is therefore very poor programming style to allow general exceptions to escape from the Addin. A relatively easy way to prevent this is to trap exceptions systematically at every entry point between the host event loop and the component interfaces - for example in every Command.Execute function:
/// <summary>
Execute
/// </summary>
public override void
Execute()
try
// Do the required function.
DoTheJob();
catch
(System.
Exception
ex)
// Pass on PdmsExceptions and PMLNetExceptions.
// Handle all others:
// (perhaps by raising a PdmsException).
private void
DoTheJob()
// Do the required function...
This recommendation does not, of course, replace the routine practice of handling exceptions at the appropriate points within the Addin code when they are anticipated and can be dealt with effectively. It simply provides a safety net for unanticipated and otherwise unhandled exceptions.
